DJI Natalia
Hi there! Thank you for sharing your concern. The DJI Goggles 3 supports panoramic and 3D video playback. You may follow the steps below:
1. Import a panoramic or 3D video to the microSD card.
2. Open the goggle menu, go to Album, and select the corresponding file for preview.
3. Toggle the 5D button down or use AR Cursor to click on the arrow at the top of the screen to open the shortcut menu. Then, access the Display Switch Settings screen.
4. Set the display mode.
* If the video source is a panoramic video, select 2D first and set FOV to Panorama.
* If the video source is a 3D video, select 3D, adjust the aspect ratio, and specify whether to enable Reverse Left and Right.
5. After confirming your selection, exit the shortcut menu for panoramic or 3D video playback based on your display settings. |
