Circle not aligned with cross when flying FPV with Neo
1116 28 2024-11-8
SRT8 Pilot
Flight distance : 378146 ft
Denmark
When I fly my Neo with Goggles 3 and Motion controller, the direction circle is never aligned with the cross. The circle is always left to the cross. Any idea to solve??
2024-11-8
OldGuy2024
Flight distance : 632428 ft
In the Menu under one of the categories the sub menu has an option to toggle on or off the center cross. Maybe just toggling it off and on might recenter the cross if it is off center.  If the MC3's center circle is off maybe reentering it by fix your problem. IIRC, you just press the rotary dial once.  Haven't used the MC3 for awhile.  Don't remember if there is a calibration option for the controller.  If there is. Another possible option to fix the off aligned icons.
2024-11-13
Bigplumbs
Flight distance : 620164 ft
You are indoors try outside where you will have far better GPS
2024-11-14
DJI Diana
Flight distance : 2408 ft
Hi there,
thank you for reaching out.
It is advisable to attempt flying in an open area to determine if the issue can be isolated. If the issue persists, please let us know.
2024-11-14
SRT8 Pilot
Denmark
I made another video flying in an open field at sunset and with a wind speed of 2 m/s.
In this case the direction indicator circle was also left to the center cross when flying straight forward.
Please note that the direction indicator circle moves left as soon as I press the accelerator.
2024-11-15
SRT8 Pilot
Denmark
When flying the Avata 2 there is no issue at all. See the video below.
2024-11-15
Bigplumbs
I am wondering if there is some sort of calibration you can do
2024-11-15
SRT8 Pilot
Denmark
I have tried all sorts of calibration of the Neo, Goggles and Motion Controller. Have tried downgrading the firmware in Neo and Goggles - and upgraded again. Nothing helps.
2024-11-16
SRT8 Pilot
Denmark
I just made a little video where the Neo is hovering, and I continually press and release the accelerator on the Motion Controller. Each time I press the accelerator the direction circle moves to the left.
I have made all possible calibrations on the Neo, the Motion controller and the Goggles. And even refreshed the firmware in all units.
Quite annoying issue.
2024-11-16
Bigplumbs
Is it actually causing a problem or are you letting it get to you
2024-11-16
Kyokushin
Flight distance : 296381 ft
Poland
He is not crazy and he is doing everything correct.
I have noticed the same issue, and it behaves in exact same way, and Avata 2 seems to have none or very small center displacement.
I did full MC3 calibration and issue persist. I have nothing more to add, because the issue is fully described by @SRT8 Pilot.
I have latest firmware on Neo/Avata2/Goggles3/MC3. And yes - this "drift"  is an annoying issue.
@DJI Support,  kindly please fix it.
P.S.
I started to look at YT videos with Neo+MC3 and issue seems to be common. On every movie i saw if someone want to fly straight then circle is shifted to the left.
2024-11-19
SRT8 Pilot
Denmark
Interesting to hear that other than me has this annoying issue. If it didn't actually work well with the Avata 2, my guess would be that it was an issue with the Motion Controller. It feels like the MC3 send some kind of an direction offset.
2024-11-19
Kyokushin
Poland
You can find some review movies on YT, and on every movie when someone is flying straight or is just starting and hovering for a while, you can observe this offset.
I think it should be forwarded to development team to take a look.
2024-11-19
SRT8 Pilot
Denmark
You are right - I have noticed that. But on most of the videos it actually seems to behave better. With the direction circle more and less straight over the center cross.
2024-11-19
djiuser_tRo9jggcWpto
Flight distance : 34104 ft
Switzerland
Same issue here: Neo - MC3 - Goggles 3
2024-11-23
Switzerland
Same issue here - Neo - MC3 - Goggles 3
2024-11-23
Bigplumbs
It makes no difference to me and does not annoy me just fly you drone and enjoy it. There are I am sure far more important things to worry about. Kerb that OCD
2024-11-24
DJI Diana
SRT8 Pilot Posted at 11-19 02:01
Hi there,
We apologize for the delayed response. Could you confirm whether you have another video in which you experienced the same issue?
2024-11-27
DJI Diana
djiuser_tRo9jggcWpto Posted at 11-23 13:48
Hi there,
2024-11-27
SRT8 Pilot
Denmark
Here is another video showing the issue. OPlease note that the direction circle moves left as soon as I press the accelerator.
2024-11-27
OldGuy2024
SRT8 Pilot Posted at 11-27 03:22
https://cdn.djivideos.com/video_play/6f14c9ca-1ddf-4e5d-b8eb-27f6dcc93d25
Just flew the Neo with MC3.  IIRC, first time since taking delivery of the Neo in early October.  Similar issue to your off center.  Just not as bad. The + is just slightly off center from the circle.  They overlap, but distinctly not centered. Guessing it is the Neo, nothing to do with the controller.  + and circle are dead center aligned using the MC3 and Avata2.
Unsure but guessing the Neo off center was from day 1.  Just don't remember it.  Or.  I've been flying the Neo manual mode with FVP RC3 and have had a few crashes.  Last one was brutal.  Scuff marks and couple propellers damaged. Maybe crashing has knocked something out of alignment.
2024-12-5
fans95124126
Flight distance : 107411 ft
I have the same problem with the circle offset to the left.
2024-12-12
MavicRich
Flight distance : 2030837 ft
I have the same issue. Circle is to the left of the crosshair.
2024-12-29
michael gunawan
Flight distance : 78100 ft
Indonesia
I feel you...
I don't experience that problem but THAT WILL ANNOYS ME....A LOT
may I suggest trying (borrow) a different MC3/GOGGLE ?
or can you go to a DJI store and try theirs ?
2024-12-29
michael gunawan
Indonesia
Bigplumbs Posted at 11-24 22:31
2024-12-29
SRT8 Pilot
Denmark
michael gunawan Posted at 12-29 16:13
I feel you...
I already tried to use different Goggles 3 and Motion Controller 3 in a shop. It made no difference. Also tried my Goggles and Motion controller with another Neo. That made no difference either. So it's really strange.
2024-12-29
djiuser_vvinEsqZmdvd
I ha ve the exact same issue, the circle is left of the cross when flying a straight line.
Neo + RC Motion 3 + Googles N3
Tried all possible calibration options, indoor or outdoor, nothing to do.
1-10 09:50
OldGuy2024
Sounding like just Life with Neo if using the MC3.
1-10 13:41
djiuser_QuFddhCxuI3s
Czechia
1-15 11:32
