Audience mode between Goggles 3 and Goggles N3
2198 19 2024-11-8
Bigplumbs
Flight distance : 620164 ft
Will audience mode work between goggles 3 and goggles N3 with say the Neo or Avata 2. I am thinking of buying a set of goggles N3 so I can fly the Avata 2 or Neo with my goggles 3 and have a friend 'come along for the ride' wearing the goggles N3
2024-11-8
DJI Diana
Flight distance : 2408 ft
Hi there.
thank you for reaching out.
Indeed, the "Audience Mode" may be utilized with Goggles N3 in the same manner as with Goggles 3 or another Goggles N3 unit.
Feel free to contact us if you have any other questions.
2024-11-9
OldGuy2024
Flight distance : 632428 ft
DJI Diana Posted at 11-9 03:56
Hi there.
How do you connect the "slave" goggle to the "flight" goggle?
2024-11-9
Mavic57Minis
Flight distance : 8923635 ft
OldGuy2024 Posted at 11-9 07:28
Its in the N3 manual section 22.
2024-11-9
DJI Diana
Hi there,
Indeed, the user manual provided by Mavic57Minis can serve as a reference.
1. Enter the DJI Goggles N3 menu, select Transmission and enter the Pilot sub-menu.
2. Turn on Broadcasting mode, and the device number will be displayed.
3. On the other goggles, enter the goggles menu, select Transmisson and enter the Audience sub-menu.
4. If any nearby goggles turn on the Broadcasting mode, the device and its signal strength can be viewed in the Audience sub-menu. Select the device number to access the liveview. Switching to Pilot sub-menu to exit the shared liveview.
2024-11-15
OldGuy2024
Thanks DJI for designing a wireless shared view between G3 and N3.
2024-11-15
William Genovese
How many spectator ("slave") googles can be "tuned in" simultaneously to watch live view?
1-24 05:22
Bigplumbs
William Genovese Posted at 1-24 05:22
I dont know that but I do know having a slave goggle degrades the signal
1-24 08:32
ProfDrYoMan
Did the OP try it? Does it really work? Spectate with N3 on a goggles 3?
1-25 10:18
Bigplumbs
ProfDrYoMan Posted at 1-25 10:18
Yes I did and it did work. You can also spectate on a phone with a cable if the phone is running the DJI fly app
1-26 00:09
JeanLuc Picard
Flight distance : 574800 ft
Is it possible to connect Goggles N3 with Goggles 2/Integra?
1-26 06:11
Bigplumbs
JeanLuc Picard Posted at 1-26 06:11
That I dont know. The goggles 3 or N3 will broadcast it is if the Integra will pick up the broadcast
1-26 08:08
Mikeyladd
Flight distance : 472 ft
DJI Diana Posted at 2024-11-9 03:56
Hi there.
Hi DJI Diana,
I have recently purchased a DJI avatar 2 with Googles 3 and have just purchased a Goggle N3 for use in audience mode. I don't have a remote controller but do have the RC motion 3.
can you direct me to a step-by-step method to setup the N3 as the audience headset please?
Tks Mikeyladd
3-6 15:54
DJI Gamora
Mikeyladd Posted at 3-6 15:54
Hi DJI Diana,
Hi there, thank you for reaching out. You can share the live view through either of the following three methods:
1. Wi-Fi Wireless Sharing: Enable “Share FPV to Mobile Device Via Wi-Fi” in DJI Goggles 3, and connect a mobile device to the goggles via Wi-Fi, and then the live view of the aircraft will be displayed on the DJI Fly app in the mobile device. Wireless sharing supports connecting one mobile device only.
2. Wired Sharing: Connect DJI Goggles 3 to a mobile device with the USB-C OTG cable and a suitable data cable, and then the live view of the aircraft will be displayed on the DJI Fly app in the mobile device. Wired sharing supports connecting one mobile device only.
3. Audience Mode: Enable Broadcast Mode in the DJI Goggles 3, and multiple DJI Goggles 3 device can connect to the broadcast channel, enabling the output of multiple real-time camera view. Audience Mode allows unlimited DJI Goggles 3 devices to be connected.
3-6 16:17
Mikeyladd
DJI Gamora Posted at 3-6 16:17
Thanks very much DJI Diana. will try out this evening!
3-6 16:21
DJI Gamora
Mikeyladd Posted at 3-6 16:21
You're welcome. Feel free to ask if you have any questions.
3-6 19:36
Mikeyladd
DJI Gamora Posted at 3-6 19:36
Hi DJI Diana,
Audience worked perfectly. Thank you!
3-9 22:17
Bigplumbs
It does deplete the signal quit a lot I found though
3-9 22:18
DJI Gamora
Mikeyladd Posted at 3-9 22:17
Hi DJI Diana,
If you have any further questions or concerns, please do not hesitate to contact our online service, you could also visit : https://www.dji.com/support?site=brandsite&from=nav.
3-9 22:58
David Mees
Something I have noticed with my 2 flying pals is that if I spectate the goggles 3 pilot and he goes out of range, the image is very blocky until he is really really close again, but with spectating the goggles n3 pilot this doesn't happen.
So do the goggles 3 prioritise the pilot more than the spectator to a greater degree than the goggles n3 ?
3-23 14:40
