Neo flyaway 2min after take off and is away
1108 16 2024-11-10
sven_neo_mavic
Flight distance : 113829 ft
Hi All :-)
I have a Mavic Pro and bought me for holidays a neo. Yesterday I was on a boot trip and I start my Neo (full battery and all is green, now wind, 25°c) and I go on 10m high. Then the drone start to be instability and they flew with maximum speed backwards and was out of control. Then they fall like a stone in the ocean and is away. I have a screen record of this and I don’t know what was happened. :-(
Had someone the same issue?
2024-11-10
DJI Diana
Flight distance : 2408 ft
Hi there,
thank you for reaching out.
We are sorry for the incident that happened to your drone. If you are unable to retrieve it, you can report a flyaway case via Flyaway Service. After successful registration, our support team will contact you and communicate with the service solution. Here is the link to submit a report: https://repair.dji.com/es/repair/flyaway.
We appreciate your patience and kind understanding.
2024-11-10
sven_neo_mavic
DJI Diana Posted at 11-10 02:39
Hi there,
Thanks for answering! I open already a case, so I will see if I get some informations what was happened. I mean if I get or buy I new one, I want not lose again a drone :-)
2024-11-10
MiniManiac
Flight distance : 1474354 ft
Was it connected to the phone or the controller/phone, if the latter then there will be flight logs available that can be used to see what happened.
2024-11-10
sven_neo_mavic
MiniManiac Posted at 11-10 06:23
I used the controller with phone. I had no issue with signal. I can try to upload the video.
Video: https://drive.google.com/file/d/1ByHm6EydiCdb0-3WvgqwIHSFMAZJ3ZZW/view?usp=sharing
2024-11-10
SeenMavic
Banned
Flight distance : 6177746 ft
2024-11-10
TheSkyIsForYou
Flight distance : 963287 ft
Poland
Most important, drone was updated with newest firmware version (1.00.0400)? Cuz before problem that you described was common even above ground.
And if I understand correctly, you were on boat trip and flew neo over the water? If yes, then remember that neo isn't safe to fly above water, and if you still want it to fly like that, then use your controller, turn neo on and wait for strong GPS lock (like above 14 satellites) before take off, then neo shouldn't fly away ( but no promise it won't).
2024-11-10
sven_neo_mavic
TheSkyIsForYou Posted at 11-10 12:16
I did the FW Update the day before.
When I start the drone I had 14 satellites and then when I was in the air I had 16 satellites.
I got not the idea that I can not fly over water, because with my other drone a net never a problem. But way it's not allow to fly over water with the Neo?
2024-11-10
TheSkyIsForYou
Poland
Dji claims that neo is strongly dependent from visual positioning. There where many people that had fly away issue above the ground (one of them was me), but after update already few people claimed that it's fixed.
I didn't test it after update, but before I managed to fly it in the night without problems.
It's like, (before update) when neo visual positioning is unavailable totally, then it switches to GPS, but if visual positioning "can see a little" then neo goes crazy.
And about over water flights, visual positioning system recognizes movement of drone and stabilize it, but when neo flies over something that doesn't have solid and stable texture then probably it's not switching to gps but goes crazy like in low light conditions.
For example if you hover neo (0,5m high) over big sheet (A3) of paper with some texture on it (like X), and you move the sheet slowly, then neo will follow it, because it's trying to maintain it's positioning above that texture.
2024-11-10
TheSkyIsForYou
Poland
I think that problem of fly aways it's that neo have poor visual positioning sensor, not so good gps module, and it's trying to much to relay on visual positioning system rather than switch to only gps, or full atti.
It would be great to add atti mode to neo, it would be much safer in case of troubles. Atti mode could be switched by fn button.
2024-11-10
MarcFez
Today I had a similar experience on a houseboat in India.
Had the drone on follow mode to follow me around the boat. When I walked to the back of the boat. The Neo just flew past me and out into the river. By the time I got my phone into manual mode it was to late and the drone just crashed into the river. I've opened a flyaway report.
2024-11-11
Alan in a hat
Flight distance : 56394 ft
I had the same neo Flyaway after one minute and it shot off at high speed in a arc and crashed . It was connected to n3 controller with android phone. I have submited a flyaway case.   Flyaway date 9-11-24
2024-11-12
Nick Egan
TheSkyIsForYou Posted at 2024-11-10 16:31
Interestingly, I’ve lost 2 Neo drones when they lost GPS location in open sky and switched to ATTI mode. In ATTI mode the drone will not fly over 100’. That was too low on both occasions for me. I time was at the very top of trees above a small chalky cliff. It drifted into the trees as GPS could not hold its position, the drone rotated and the direction was lost on the screen map. Return to home won’t work. Second drone went to ATTI mode and flew off at speed. Covered almost 5000 ft. Dropper to 100’ and I think flew into trees at a memorial site. Interestingly to it said it had not enough battery at 68%. Both times very random. Luckily these drones are very cheap.
1-7 01:22
relaxosmo
Flight distance : 901965 ft
Hungary
even when its cheap, its unacceptable!!
Use GPS for position holding when something strange is at bottom or
drift in normal ATTI mode. But accelerating, random directions, flyaways is totally unacceptable and risky too!
1-7 03:25
fans3914c97a
Flight distance : 1427904 ft
India
I am also getting the same Fly away issue. Three times my neo went away with full speed in backward position and without any control. I already updated my Neo with the latest firmware, But still sometimes i get same flyaway issue in open field.
Dear DJI, kindly provide some solution on this issue.
1-7 03:28
JamesCodesThing
Hey, just a heads up that I've been trying to catalogue the reports of this issue that have cropped up on reddit, because there are lots of them and I had no idea this was an issue until it happened to me:
https://www.reddit.com/r/DjiNeo/comments/1hvsfvg/can_we_get_a_sticky_going_for_the_flyaway_issues/
You can see a couple videos of the kind of flyaways that seem to be consistently happening; regardless of flight conditions.
1-7 06:32
Meanskunk
In the original/Official DJI Neo video they show it flying over water surely that’s False advertisement
1-10 10:47
