Mini 4 pro distance setting disobeyed
400 8 2024-11-22
moth
Hi
Our Mini 4 pro won't fly very far. This is with the DJI controller with the inbuilt screen NOT the version that holds a separate phone.
The distance is set to >7km on the controller screen menu safety section.
I see reference to the fly app in the manual. I thought it was all controlled with the controller screen and didn't need the app?
Why isn't it going the distance?
Thank you
2024-11-22
DJI Gamora
Hi there,
Thank You for reaching out. We are truly sorry for the inconvenience you are experiencing. Could you confirm id you are using DJI RC 2 with your DJI Mini 4 pro? Is there any error message prompting on your screen and by the mean wont fly far could you confirm the minimum distance your flight is stuck at? Please send us a video recording of the problem. This will allow us to investigate further and provide you with the most accurate solution based on the specific issue you're encountering.
We are looking forward to your response for further assistance. Thank You
2024-11-22
DowntownRDB
Flight distance : ****
If Beginner mode or Tutorial mode are enabled in the Fly App your distance will be limited.
2024-11-22
Labroides
Flight distance : 26781877 ft
How far does your drone fly from the home point?
Where are you flying?
The distance setting in the app is for setting a Max Distance Limit .... not something to make the drone fly further.
The only way the drone could "disobey" your setting would be if it ignored the limit you set and flew beyond the that.
The interference in urban areas will reduce your max distance considerably.
To achieve long distances, you need to fly in an interference-free location.
2024-11-22
PintorMX
Flight distance : 772375 ft
Mexico
From what I've read, if you haven't logged on to DJI with your credentials in 90 days I think, your distance is limited in order to deter theft.
2024-11-22
MiniManiac
Flight distance : 1474354 ft
Ok so its the RC2
So its set to max distance or near enough
The App is for people who use a phone with the RC-N2 controller and is already installed on the DJI RC2
As explained above, the app is built into the RC2
Try the suggestions above, such as checking checking you arent in beginner mode and are logged into the app.
Thank you
You are welcome
2024-11-22
NBGRobbo
Flight distance : 12349 ft
PintorMX Posted at 11-22 05:43
This. You are logged in?
2024-11-22
MiniManiac
NBGRobbo Posted at 11-22 12:37
Logged into the app, as in using a user name and password, its in the settings section of the app
2024-11-22
moth
Hi all
Thank you everyone. The pilot has done something online and has sorted that now. The thing was registered online when bought but maybe the required buttons weren't pressed at that time.
2024-11-23
