Cetaman
Flight distance : 2494390 ft
Aloha Darren,
POI is a really sweet tool for video. I have done spirals up to 400 feet and back down - really cool effect. You can also adjust the gimbal angle very slowly to add to the effect. Using the out facing camera orientation, as sploodge suggested, provides a faster pan when you need it like if you want to record a faster orbit than the slider allows (you can also use the right stick). I had 3 ducks checking out my P3 yesterday just before I got the Low Battery Warning - a great use for sploodge's suggestion; except no more battery and they came back four times before I had to land!
Facing the camera inward - across the center point - allows a very slow pan like when you use 4K. Both techniques are rock steady even in windy conditions and do not even look like the P3 is orbiting a 40 foot circle. Instead, the P3 appears to be spinning on its axis in the video.
Aloha and Drone On! |
