Distored image on M30T Wide camera
320 3 2024-11-25
cypherb
Hello!  I just started flying the M30T have been trying to fly a basic ortho map misssion.  Processed maps are not coming out as expect, lots of misalignment.  Im not so cocerned about gps spacial accuracy, more interested in picture allignment for presenation purposes.  Flying at 200ft with 80% front and side overlap, the following distortion:
Looking at the images individual images, there seems to be a lot of distortion, here is an example.
Is this image quality normal for the M30t Wide Camera?
2024-11-25
LV_Forestry
Flight distance : 4726654 ft
Latvia
Which software are you using ?
2024-11-25
AR_AirPrecision
Flight distance : 2683589 ft
Belgium
We mainly use the telelens on the H20T as the wide is not as good. Much beter in combination with the thermal ( on 2x ).
Not idea on the M30T...could also be a software issue as LV_Forestry pointed out.
2024-11-26
Hoarfrost
Flight distance : 705974 ft
I had similar issues with my M30 when creating an orthomosaic. Problems arose where there was little variation and a repeating pattern without distinguishing details like shingled roofs. I had better luck when there were other things in the pictures that allowed the software a better chance of anchoring the photos (I was using WebODM). Forests were also a challenge.
I eventually bought a Mavic 3E which solved most of the issues and allowed me to fly much faster without distortion. If I wanted better results with the M30, I had to fly no faster than 18 mph. With the M3E, I could fly the same routes at 33 mph.
This is just my experience. Others here should be able to have more technical answers.
2024-12-20
