DJI Stephen
FEL TAN Posted at 12-8 21:49
i had an issue with dji mic mini while i connected my reciever in osmomaction 3 after 1hour of recording my osmo action 3 indicated in the screen is overheating and suddenly stop recording.so i think it because of the receiver of dji mic mini connected so it suddenly happen the overheating issue of oa3 and stop recording and it so very hot it maybe it consumed battery life of oa3 when it connected the reciever of mini 3. i hope it will improved on upcoming updates of dji
Hello FEL TAN,
We apologise for the inconvenience you've experienced. When you connect additional devices, such as the DJI Mic Mini receiver, it can increase the processing load, which may lead to increased heat generation. The device is designed to display an overheating warning to protect itself when the internal temperature reaches a certain level. The Osmo Action 3 is optimized for activities like skiing, diving, and cycling. In these scenarios, using high resolution or high frame rates is supported by the cooling effect of the wind, allowing for longer recording times. If you're primarily using the camera for recording daily life, we recommend using a resolution of 1080P30, as this is the standard for most online videos. This setting will also help reduce storage space usage and make editing easier.
Could you please let us know your current firmware version? DJI released the latest firmware for the Osmo Action 3, version V01.04.01.10, on September 20, 2024. Please kindly try to connect your device to your phone to update the firmware.
We hope this information helps, and we wish you a great day.
Thank you for your understanding and support. |
