DJI MIC MINI Beginners Guide - Start Here
659 19 2024-11-27
DAFlys
2024-11-27
DowntownRDB
Flight distance : ****
Very nice find DA.    Very comprehensive Mic Mini guide.
2024-11-27
DAFlys
DowntownRDB Posted at 11-27 12:07
He got it out quick too.     Although not the 360 launch lots were expecting.
2024-11-28
DowntownRDB
DAFlys Posted at 11-28 01:50
After seeing the 360  already cleared the FCC and with the threat of 60-100% tariffs starting in January I would have thought DJI would have felt some sense of urgency to get the 360 released.
2024-11-28
DAFlys
DowntownRDB Posted at 11-28 05:47
It must be close then.  Maybe in the coming weeks.
2024-11-28
DowntownRDB
DAFlys Posted at 11-28 05:52
Reddit rumors had it being released prior to Thanksgiving but as you know that turned out to be the Mini Mic instead.
2024-11-28
DAFlys
DowntownRDB Posted at 11-28 06:17
Which is funny as Id not seen any rumours for the Mic mini, and completely missed the fact that orginaldobo showed it on video by mistake.
2024-11-28
DowntownRDB
DAFlys Posted at 11-28 06:24
Sounds like something originaldobo would do.
2024-11-28
Natastrophe
Flight distance : 34567 ft
Anyone had issues connecting to the receiver via bluetooth? It wont pair, just works via usb-C
2024-11-29
THE.G33KED
Hello, lovely video. Could you confirm that this works for the Action 4?  Can you change the NC level setting from the camera when connected thru  DJI OsmoAudio™ Direct Connection on Action 4?
2024-11-30
Montfrooij
Flight distance : 2845026 ft
Sounds good.
I'm investigating this instead of the 2 for the combo that I'll get with the Pocket 3
2024-12-5
DAFlys
Montfrooij Posted at 12-5 08:49
Sounds good.
It seems really good value if you dont need to connect an external mic to the mic
2024-12-6
Montfrooij
DAFlys Posted at 12-6 01:48
The only downside I can think of right now is that it does not record internally. So if the connection is somehow having issues, you're screwed.
2024-12-6
DAFlys
Montfrooij Posted at 12-6 02:17
And no float32 audio which would be very useful.
2024-12-6
Montfrooij
DAFlys Posted at 12-6 02:27
Against clipping.
But from my understanding the real problem is not the clipping of the signal, but the clipping from the low SPL of the mics itself (both Mic 2 and Mic).
So you can still end up with clipping even though you set the gain low.
It's common with these small mics btw, but I noticed in one of the wind demos.
2024-12-6
DAFlys
Montfrooij Posted at 12-6 02:37
Against clipping.
I thought the main point with the 32bit audio was that you didnt need to set a gain until after the recording is made.
2024-12-6
Montfrooij
DAFlys Posted at 12-6 03:02
Yes.
But.
The mic itself (the physical thing) has a maximum sound pressure it can handle.
And with Mic 2 and Mic they are quite low, so you can still get distortion if your sound is too loud.
With some mics I had, this even happens at loud speaking levels. Not sure if the DJI Mics are that sensitive.
And, unfortunately, you can't do anything about it, other than either putting something 'over' the mic (which also reduces the clarity) or putting the mic somewhere further away.
Which is not always possible or enough.
2024-12-6
DAFlys
Montfrooij Posted at 12-6 03:24
Yes.
But.
Thats very true,   I wonder then why they make such a big deal about the float audio.
2024-12-7
Montfrooij
DAFlys Posted at 12-7 00:45
Easy marketing.
(and it does help in some situations, mainly with high dynamic range).
2024-12-7
Aspendas
Turkey
Hi everyone, I am wondering is there a anybody who uses mic mini with dji osmo pocket v1. Is it compatible?
yesterday 01:20
