simac_fpv
Flight distance : 2294262 ft
Malta
Unfortunately, despite a recent firmware update mainly 01.02.03.30, the issue with the ISO parameters in the Manual Exposure Settings, specifically when using the 100–200 and 100–400 ISO ranges remains unresolved. These ranges do not function as expected, limiting flexibility and control over manual exposure, which is critical for precise shooting conditions..
Additionally, I’ve discovered another significant bug that requires immediate attention. The Color Recovery feature in the Color settings is not functioning as intended. This feature is supposed to provide a live preview in Rec709 while recording in D-Log M. However, when Color Recovery is set to ON, recordings are incorrectly captured in the Rec709 color profile instead of D-Log M. To ensure recordings are in D-Log M, users must manually switch the Color Recovery setting to OFF before recording.
Both of these issues significantly impact usability and workflow. I urge you to prioritize addressing these problems in an upcoming firmware update.
