Power dongle + Expansion Battery + Solar Panel Adapter Module
627 13 2024-12-2
Gintaras_525
Flight distance : 30292 ft
Lithuania
Hello,
can I use DJI Power 1000, DJI Power Expansion Battery 2000, DJI Power Dongle and DJI Power Solar Panel Adapter Module (MPPT) together?
Connection scheme can be like this:
DJI Power 1000 SDC <--------> DJI Power Expansion Battery 2000 SDC port 1
DJI Power 1000 SDC Lite <---> DJI Power Dongle
DJI Power Expansion Battery 2000 SDC port 2 <---> DJI Power Solar Panel Adapter Module (MPPT)
Will this work?
I didn't find any information in DJI Power Expansion Battery 2000 manual about possibility to directly connect  DJI Power Solar Panel Adapter Module (MPPT)
2024-12-2
Atlantis-99
Flight distance : 751542 ft
Poland
Hi . I think it will work for sure in combination STATION SDC-ExBAt , MPPT- STATION SDClite , ExBAt- Dongle . But in this case youll get only 400w i guess to charge both batteries .  Im now waitiong for a delivery of station + exbat  and will make some experiments with charging . I think i will make a new topic for such discussion
2024-12-2
mavicme
Flight distance : 35738 ft
I'm assuming the power 2000 can power external devices using the SDC ports without it being connected to the main unit (power 1000)?   If so, will there be SDC dongles for AC, usb, etc?
2024-12-2
Atlantis-99
Poland
IMHO 2000 is accessory for Power 1000 . adn you are talking about accessory for the accessory )) i think its not a good point for DJI
2024-12-2
mavicme
Sergey Shevelev Posted at 12-2 13:12
I wouldn't say it's accessories for accessories.  I can also be used on the main unit.  The purpose is that if you build a 11k wh power station with all these expansion packs, that entire unit would need to to stay put.  Why not allow you to remove one expansion unit and use it independently in a car or wherever.  Once done, add it back to the stack.  Flexible.
2024-12-2
Atlantis-99
Poland
Oh , yes , maybe you are right in you point of view. In 11kWh two high woltage outputs with totally only  2.2 kw  looks really weird . Tha same as only 1 SDC connector will be free . It will be better to have more powerful main unit with capacity smth like 4 or 5 kwh . for integration in smart house . this set of main unit and one EXTbat i found as best solution for camping etc.
2024-12-2
Atlantis-99
Poland
there was released a manual for that exp battery . And ))) nothing about connecting the solar panels with MPPT to that battery . The only thing is that do not connect fast drone battery charging adapters , and avoid to touch output connectors )) . I m now still waiting for my battery and will check it , or mayme try to make some kind of review on it . also with fast charging adapter.
2024-12-6
Gintaras_525
Lithuania
Answer to primary question  is YES.
Found answer in this video, time 2:10:
https://app-h5.dji.com/ZGppLWdvL ... d-b967-39e044a69afc
2024-12-19
Atlantis-99
Poland
Thanks for sharing . And its the only free port that will be available when Power Dongle is using . By the way video you gave is not loading through that link .
2024-12-19
Gintaras_525
Lithuania
Atlantis-99 Posted at 12-19 03:25
Video is "DJI Power Super Fast Carger | Car Scenario".
Found on Youtube too:
2024-12-19
Atlantis-99
Poland
Yeah/ I have already got the charger . and install harness . Hope DJI finaly resolve that shipping problem for the 2000 kw battery and i will also  test it
2024-12-19
davidjuan
Pakistan
Your setup sounds interesting, but I’d recommend checking compatibility carefully. The DJI Power Expansion Battery 2000 manual not mentioning a direct connection to the Solar Panel Adapter Module (MPPT) might be a red flag. It’s possible there could be voltage or current mismatches. If you're aiming for a seamless solar integration, you might want to explore alternatives like a dedicated solar generator that supports modular connections and ensures safe power distribution. Let us know how it works out!
2024-12-20
Atlantis-99
Poland
davidjuan Posted at 12-20 02:53
This also explains why our team able to arrange the package to be picked up by courier in the first place is really weird thing that explains nothing except do not touch conectors ))
2024-12-20
DJI Gamora
Gintaras_525 Posted at 12-19 01:51
https://app-h5.dji.com/ZGppLWdvLT/index.html#/video?uid=2c636ee3-157f-434d-b967-39e044a69afc
Hi Gintaras_525.
We do apologize for the trouble that this has caused. Thank you for keeping us posted. We're glad to hear this has been addressed and thank you for sharing the resolution information.
Feel free to contact us if you have other inquiries. Have a nice day ahead!
2024-12-20
