triggus
Hi Bussty, this is my conclusion as well and the reason why I think Air3s is a keeper despite some disappointments in regards of the 1" inch QB sensor in comparison what can be achieved with much older Air2s.
This possibly need more testing but the 50MP mode seems no go for any serious photography, noticed unacceptable level of color noise in well lit scenes. its much better in the 12MP mode but this can produce some artifacts at times that I havent seen on Air2s. Not to mention slightly less detail and smaller pixel count in 12MP compared to Air2s.
However the 70MP and Freepano indeed looks like game changer. The pictures yoy analysed and compared in your post, I had very limited time for tests when I took them and this was my first ever attempt to use freepano.
I believe with some practise the framing could be done much better to reflect 24mm (hower I would prolly go for slightly larger frame as this gives more room for cropping or refining composition in post).
to get perfect reflection of 24mm you need to frame the scene at 24mm remember details of top left corner and bottom right corner. change the lens to 70 and in Free pano aim the the start and end frames at these two mentioned before. Freepano is so flexible.
Anyway I found the results stunning, there is no other flying camera atm that can provide such a detail with such an easy and quick process.
In theory you can achieve same with air3 or mavic3 pro manually shooting 70mm frames and stiching them in post, its lots of time consuming painfull work probably deffering 90% of photographes from even trying.
However freepano makes this process so quick and painless that makes it actually workable for almost any shot. The way drone is processing the pano jpg looks very decent off the shelf for the example above it was 30MP - very decent resoluton, a bit of love in post, 5 minutes edits and quality is comercially viable. For better results/or specifc needs and details you can play with the dngs (for the example aboce stiched produced 130MP with incredible detials) nicely stored in dedicated folder.
I just hope if the 50MP issues or some wierd artifacts sometimes produced by 12 mp are result of the processing in drone software/ pipline rather than the sensor itself - Dji will look into and try to fix it in further updates.
