DJI Gamora
Hi Petrified Shrimp,
Thank You for reaching out. We are truly sorry for the inconvenience you are experiencing. A drone equipped with visual sensors and Advanced RTH capabilities would try to bypass GEO Zones and Restricted Zones, if any, during its auto RTH flight. If the drone cannot avoid GEO Zones, it descends to the altitude of 120 m before proceeding with the return to home (if the RTH altitude is below 120 m, it continues returning to home normally). In the case of Restricted Zones, the drone hovers and awaits further instructions.
• The aircraft cannot return to the Home Point if the GNSS signal is weak or unavailable. The aircraft may enter ATTI mode if the GNSS signal becomes weak or unavailable after entering Failsafe RTH. The aircraft will hover in place for a while before landing.
• It is important to set a suitable RTH altitude before each flight. Launch DJI Fly and set the RTH altitude. In RTH, if the current altitude of the aircraft is lower than the RTH altitude, it will automatically ascend to the RTH altitude first. If the current altitude of the aircraft reaches or is higher than the RTH altitude, it will fly to the Home Point at its current altitude.
• During RTH, the speed and altitude of the aircraft can be controlled using the remote controller if the remote controller signal is normal. However, the aircraft cannot be shifted leftward or rightward. When the aircraft is ascending or flying forward, push the control stick completely in the opposite direction to exit RTH, and the aircraft will brake and hover.
I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You! |
