Problems with Mic Mini TX
1307 0 2024-12-5
efati
Poland
I have 2 (rather minor) problems with Mic Mini TX:
1. Within the DJI Mimo app there is a setting called Power Button for Noise Cancellation. This is supposed to enable/disable the power switch for selecting noise reduction. However, whenever I disable this setting in Mimo app it becomes automatically reenabled after connecting to the camera (in my case Action 4). It looks like the camera is overwriting the settings with its own parameters whenever connects to the mic. And, unfortunately, there is no setting in the camera to disable the power button, so it chooses its predefined default value which happens to be "enable"...
2. The audio meter of DJI Action 4 does not reflect the actual recording level in the camera while recording with Mic Mini. If you disable the limitter (Clipping Control) and record loud source, the clipping happens right after entering the yellow zone instead of the red one. If I connect another microphone or audio interface, the clipping happens when the meter reaches the end of the red zone and the yellow zone is treated as the safe default zone between -18dB and -6dB.
Apart from that I'm quite happy with the purchase!
2024-12-5
