andreirby
Russia
Hello guys!
Im going through some trouble with my P3 advanced. I've reached a point when there is nothing left to try, so I count on your help and advice.
Here is the story.
I had to replace the main board due to a shortcut. When a new board was installed and connected, everything worked (connection to RC, video signal, gimbal), but the gumbal was
beeping (like this DD....DD....DD....DD). I thought the reason might be FW mismatch between main board and the gumball. So I tried to update firmware first to 1.3.2 then to 1.4. Here I faced the problem that update falied every time. I tried to reinstall it countless number of times (trying all methods describer on the forum, letting it scream out for as long as the full battery lasted) with no success. Every time it ended with solid red light and continuous beep. Needless to say that after failed updates I got limp gimbal and no video from camera. RC still connecting though.
At some point the FW update wouldn't start at all. I insert the card, with .bin on it, power on and nothing happens, copter just sits there with limp gimbal and beeps (no red/green blinking light on gimbal). I am still able to connect to it though. RC connects with a green light and the app connects too. It shows 100% signal strength but no video signal.
Contacting support didn't help much. Following their advice I did IMU calibration in the app. There were no success/fail messages on the screen, but LEDs were blinking yellow and then switched to green. When they became green I restarted the quad. And everything got worse - no lights, constant beeping from ESCs instead of start melody and the gimbal still beeps twice and is limp. If I let it sit for a while it would keep beeping with ESCs and gimbal. The gimbal blinks green. An interesting thing, if insert sd card with 1.4 FW it would do nothing, but with a 1.3.2 FW I got that red/green blinking light, so I left it, hoping the firmware will settle down. One battery later, it is still beeping as hell with ESCs and gimbal. There is no txt results or log file on the card, but some kind of "UserSetting.bin" file appeared.
No respond from the support so far, so I decided to ask here, maybe someone has got an idea, what can bring my bird back in the air.
Thank you !
