D_The_Producer
Flight distance : 1185449 ft
Thailand
Atlantis-99 Posted at 12-16 23:36
And again DJI And weird compatibility ... both OS4 but not supported . Why N3 was released If it can be used with only with this two models ... that are working in the same O4 ...nobody will answer you . As for your question - Goggles 3 will fit the Mini4Pro . If you will then would like to try FPV - it will also be compatible with DJI Air O3 unit for digital VTX .
I like the quality of DJI products but such wierd things with compatibility or firmware updates are making think twice before buying new products .
There isn't many other options and they know it. I've got the Neo and the Mini 4 Pro, and I just got the FPV Controller 3 and the Goggles N3 and I can't only use the latter with the Neo, a much cheaper drone! It just doesn't make any sense... But this is DJI! If you fly their Enterprise products everyday for work, like in my case, you know that they really don't care about the customer and trying to find any logic is pointless. |
