AVATA 2 drone version too early
360 6 2024-12-22
michael gunawan
Flight distance : 78100 ft
Indonesia
Hi,
just got my AVATA 2 but upon activation, with GOGGLE N3, got the DRONE VERSION TOO EARLY error
after some research, managed to activate and update firmware through DJI ASSISTANT on the computer
after that = all working fine
my Q is that in my DJI FLY app/DEVICE MANAGEMENT, the AVATA 2 doesn't apeear
what to do ?
Thank you
2024-12-22
DJI Diana
Flight distance : 2408 ft
Hi there,
thank you for reaching out.
Please uninstall and reinstall the DJI Fly application from this link (https://www.dji.com/downloads/djiapp/dji-fly) to see if the issue persists. Additionally, refer to the article below for the binding process. If the issue continues, kindly try using a different recommended mobile device to help us isolate the problem.
DJI Fly App Account and Device Binding/Unbinding Guide
2024-12-22
michael gunawan
DJI Diana Posted at 12-22 19:10
Hi there,
Thank you Diana,
Following the binding instructions works.
2024-12-23
DJI Diana
michael gunawan Posted at 12-23 03:07
Thank you Diana,
Hi michael gunawan,
we appreciate the update provided and are glad your issue has been resolved.
Feel free to contact us should you have any other questions.
2024-12-23
Evolved-Imaging
Flight distance : 328294 ft
Im having the same problem but Assistant 2 isnt picking up my Avata 2 either.
In the goggles N3 i get the “Version too early” so ive been unable to connect or update.
My goggles and motion controller are connected and updated alongside my Neo.
2024-12-27
michael gunawan
Indonesia
Evolved-Imaging Posted at 12-27 11:45
Hi,
May I suggest try using a different cable...
Is the DJI ASSISTANT 2 detecting your NEO /controller with the same cable?
Even if it does, as silly as it sounds, I found that cable X works with this device and won't work with that device, while cable Y could give a different result.
Just my 2 cents
2024-12-27
Deneys Botha
Got it working now thank you. I tried a different cable and completely reinstalled the DJI assistant 2.
2024-12-30
