DJI Wanda
Hi, there
Thanks for yoru information.
Please follow the steps below:
1. If you have regular stereo headphones with a 3.5mm plug, you can plug them into the OUT jack of the receiver to listen. If you only hear sound in one ear, there's a problem with the connection. If you hear sound in both ears, then the connection is fine.
2. Replace the 3.5 mm audio cable.
3. If possible, conduct a cross test with another camera to confirm whether the issue is caused by the camera port anomaly.
4. Connect the camera to the monitor port of the DJI Mic 2 Receiver using a 3.5 mm audio cable. If the audio output through the monitor port is normal, it can be concluded that the Receiver audio output port is faulty. In this case, we suggest you send it back to the repair center for inspection. |
