Flying two Mini 4 Pros
473 6 2024-12-29
jp1717171717
I need to fly two Mini 4 Pros at the same time. They both use the RC 2. One will be circling the subject and the other I will be maneuvering manually. Do I need to have one frequency on 2.4 and the other on 5.8 to make sure there isn't an issue? Thanks!
2024-12-29
Labroides
Flight distance : 26781877 ft
There won't be any issue.
You could fly ten drones and there still wouldn't be an issue.
2024-12-29
Serg SSA
Flight distance : 14496650 ft
Russia
Labroides Posted at 12-29 23:28
If you launch 10 drones, there will definitely be problems, even if you launch less than 10
DJI is very demanding on the frequency band, this is not wifi, here the frequency band is much wider and several drones will create a problem for each other.
This is clearly noticeable if you fly, for example, with DJI and any analog drone, DJI will simply drown it out.
2024-12-30
Labroides
Serg SSA Posted at 12-30 09:12
You could fly ten DJI drones together and there won't be any issue.
2024-12-30
Serg SSA
Russia
Labroides Posted at 12-30 12:59
Try it )
2024-12-31
Labroides
I haven't flown 10, but have heard from someone who has.
I've only flown three myself.
2024-12-31
ryguy80
Flight distance : 17480 ft
Do you have a waiver? It's not legal in the U.S. under FAA Section 107.35, "no person should operate or act as a remote pilot in command or visual observer in the operation of more than one unmanned aircraft system at the same time."
2024-12-31
