DJI Diana
Flight distance : 2408 ft
Hi there,
thank you for reaching out.
Please follow the steps below and see if you can isolate the issue.
Please confirm whether it is the latest version of the App.
1. For drones without internal storage, check whether a microSD card has been inserted. For drones with internal storage, check whether the selected Storage Mode has sufficient storage.
2. Check whether the flight mode/remote controller mode is P mode and whether the signal is strong. If the aircraft has entered the ATTI mode or another mode, the QuickShots function cannot be used. We recommend switching the remote controller back to P mode and ensuring that the signal is strong.
3. Check whether the vertical takeoff height is over 2 m. The QuickShots feature is not available if the takeoff altitude is lower than 2 m. We recommend you to fly the aircraft above 2 m before using QuickShots.
4. Check whether you have selected the target and tapped Start. If the target is not selected or the Start button is not tapped, QuickShots cannot be triggered.
5. Check whether the lighting conditions are good and whether there are obstacles around the subject If the light is insufficient or there are obstacles around, there might be a calculation error due to the visual element of the target distance. As such, the DJI Fly app will not be able to stitch Quickshots videos. When the light is sufficient and there are no obstacles around the target, keep an ample flight distance to prevent the influence of visual elements.
6. May we confirm on which mobile device are you using?
7. Refresh the aircraft and RC firmware version using DJI Assistant 2.
Please keep us posted.
