DJI Mic2 - USB / Bluetooth very low volume on MacBook Pro M2
159 2 1-1 16:22
CandidB
Flight distance : 140584 ft
Is use a Mic2 with my Osmo Pocket 3 and I have an additional Mic2 Bundle (2x transmitter, 1x receiver). In conjunction with my Osmo Pocket 3 audio volume and quality of the DJI Mic2 is fine. Only the noise is to high for my liking.
Today I tried to use the Mic2 with my MacBook Pro M2. First I bound it directly via Bluetooth. That worked but the volume was way to low. I nearly have to eat my Mic2 in order to get an acceptable volume.
Then I used the DJI Mic2 receiver via USB with the same result. On the receiver I have set the transmitter gain to +12 dB, receiver gain is 0 dB. With this I get a good level displayed at the DJI Mic2 receiver but the volume of the signal that my MacBook Pro M2 receives is very low and noisy. I raised the receiver gain from 0 to 12 dB with absolutely no difference in the signal my MacBook Pro M2 receives. So the DJI Mic2 receiver gain seemes not to be existant ;-)?
My result: Mic2 with direct binding via Bluetooth or with the Mic2 receiver over USB does not work on a MacBook Pro M2 at all. That is an unacceptable situation for such a high quality and high price product from DJI!
Mentioned in passing: I have an AnkerWork M650 what is a copy of the DJI Mic(2) I would say. That works very fine with my MacBook Pro M2!
I have installed current version on DJI Mic2 transmitter and receiver: v04.05.01.11
If DJI has a need of beta tester for DJI Mic2 on a MacBook Pro M2 I will be ready ;-)
1-1 16:22
DJI Natalia
Hi there, CandidB. Thank you for sharing your experience and input with us! Your feedback has been noted and will be passed along to the relevant departments. Rest assured, we take all customer feedback seriously and use it to continuously improve our products and services.
Thank you for your support and understanding.
1-3 04:12
CandidB
I ordered a DJI Mic MINI Bundle with receiver in order to test against DJI Mic2 with my MacBook. When I connect one of the MINIs via bluetooth it's the exakt same bad situation as with the MIC2. The volume is much to low. When I use the MINI receiver through USB-C it is better because the gain controller on the receiver does work on the Mac. So when I set it to +12 dB I get a much louder volume recorded. In FinalCut for example I now can do recordings and only have to do little modification (loudness filter and/or only 3 dB gain) in order to have reasonable sound.
So what I can say is, that the gain of the Mic2 receiver does not work but the gain of the MINI receiver does work in conjunction with a MacBook Pro and MacOS Sequoia 15.2 (DJI Mic MINI firmware 01.01.00.39, DJI Mic2 firmware v04.05.01.11). So I think it should be possible for DJI programmers to fix this problem for Mac easily for the Mic2 (receiver).
1-8 11:43
