DJI Gamora
Hi there, thank you for bringing this to our attention. The audio signal input to the Osmo Pocket 3 USB-C port must be a digital signal of 48k/16-bit or higher. If adapter cables are used, the adapter cables must also support 48k/16-bit digital input and output.
1. It is recommended to use a USB-C adapter that comes with the wireless microphone to connect it to Osmo Pocket 3 instead of using a 3.5 mm adapter, as 3.5 mm outputs are predominantly analog signals.
2. Disable the ""easy playback"" function (a feature that prevents the mobile phone's internal speaker from being automatically disabled when the microphone is connected) of the microphone, and avoid using an adapter cable. These prevent recording failures caused by protocol incompatibility.
However, please be aware that the Audient Evo 4 is not included in the list of recommended third-party microphones for the Osmo Pocket 3. However, you are welcome to try the steps provided to see if they resolve the issue. Thank you for your understanding and support. |
