Mark184
Flight distance : 167001 ft
FabioV Posted at 1-7 02:52
I suggest to shot in HLG mode. It is a HDR 10bit mode and it can be used out of the box In DaVinci because it fully supports it as Color Space REC 2100 HLG. By opposite, Dlog-M is a proprietary DJI format it is not documented and then DaVinci Resolve does not provide any native support. You can just use the provided DJI LUT, but this approach does not provide any real advantages respect shooting in Normal mode. With clips in HLG, you can generate a HDR 10 bit deliverable (REC 2100 HLG) or you can obtain a 8 bit Rec709 deliverable just applying a Color Space Transformation, or just setting up a DaVinci YRGB Managed project.
Thanks for this great info! I clearly need to do some more reading on this subject. Sounds like shooting in HLG mode is the way to go. Do I need to set my project settings in Resolve for the clips to be recognized as REC 2100, or do they simply come in that way when I bring them into the media pool? Same question with output for delivery- I’ve seen the encoding choices of Main, and Main 10, presumably for 8 and 10 bit output files. Is that the setting to create the REC 2100 HLG files you mention?
Thanks again! |
