DJI Wanda
Hi, there
Thanks for sharing your concern.
According to your description of the problem, our engineering team tried to fly with the latest version of the same model flight firmware and APP, it is possible to add waypoints by clicking on the map.
If you fail, we suggest you try to update the firmware and app version to see if it can be resolved.
In order to better help you resolve it, please provide the following information, we will forward it to the relevant team for further checking:
1、Try to fly again by using the waypoints and record the screen. Provide the time of the issue happens
2、Export app logs
3、Synchronize and export the export the aircraft body log when the problem is occurs. |
