ChristopherHM
Thank you , i will try that . I currently have it hooked to the HDMI on an extra flat panel Tv . For the most part , it seems much better . I did see it drop out and back on when i powered up the drone one time. Of course , this tv is set to a much lower resolution ( than the RC2) which i believe would actually help alleviate the problem. Please correct me if im wrong . Also worth mentioning , i tried another 90 hdmi adapter on the tv and it worked great . I never could get it to work at all with the LUT11 monitor .
So yes , i will try a new cable . Besides that , im wondering if there may be an issue with the HDMI 1 port on the LUT 11. I’ll also try the HDMI 2 port to rule out that possibility. |
