DJI O4 Air Unit Pro DETAILED Review & O3 & Avata 2 Comparison
377 14 1-9 05:53
DAFlys
1-9 05:53
Montfrooij
Flight distance : 2845026 ft
That was quite in depth!
1-10 00:22
DAFlys
Montfrooij Posted at 1-10 00:22
Yes,  I liked how they did the latency tests.
1-11 00:59
Montfrooij
DAFlys Posted at 1-11 00:59
They went all in on that one.
Funny enough I recently did my own latency test with my audio interface. Similar, but different.
1-11 02:37
DAFlys
Montfrooij Posted at 1-11 02:37
Was that a clap test?
1-11 02:42
Montfrooij
DAFlys Posted at 1-11 02:42
Something similar, but only with audio.
And then aligning the 2 sources in my DAW to see where the 2nd waveform started.
1-11 02:44
Montfrooij
Like this
1-11 02:45
DAFlys
So they have a built in mechanism for adding/removing delay?
1-11 02:46
Montfrooij
DAFlys Posted at 1-11 02:46
In fact, the DAWS do, so incoming audio is delayed by xxx ms to match the latency the software is introducing.
But this was different.
My audio interface allows for sending audio out and then I returned it after sending it though an FX box (analogue, so no latency) and recorded both incoming and returned audio to see the internal latency.
This is a digital interface, so everything is processed digitally and then converted back to analog. Which apparently takes 1ms.
1-11 02:49
DAFlys
Montfrooij Posted at 1-11 02:49
1ms seems pretty good though.
1-11 02:55
Montfrooij
DAFlys Posted at 1-11 02:55
It's perfect.
Not noticeable
1-11 02:56
Montfrooij
The only problem could be that the 2 could get out of phase, so they cancel eachother out (in some frequencies).
But I never record dry signal coming through this send FX loop, so I'm good.
1-11 02:57
DAFlys
Montfrooij Posted at 1-11 02:57
But once its setup why would it change?
1-11 03:04
Montfrooij
DAFlys Posted at 1-11 03:04
The DAW is fine, but this is my interface.
It can't do this compensation, so it's just something to know and work around.
It will screw you up once and then you know what to do
Very common in the mixer business btw.
1-11 03:06
Montfrooij
You see more and more FX pedals with a true dry bypass exactly for this reason. So you don't get any latency (and don't alter the sound either)
1-11 03:07
