AMF mode not working when combined with 2022 Lidar Range Finder
207 2 1-14 02:35
MJMk
Hi I have the 2022 Lidar Range finder and focus wheel successfully working with the Focus Pro Grip. It has copied the profile over from the range finder and everything focusses perfectly when in Autofocus mode.
However when I select AMF as the focus option the AMF does not work. I can manually switch to AF by selecting this on the Range finder itself, however this does not allow for the AMF functionality.
I am assuming that the AMF has not been implemented as yet for the 2022 Lidar Range Finder. It would be great for DJI to confirm if this is a feature that is been worked on or if it is a straight up bug.
Thank you.
1-14 02:35
DJI Susan
Hi there. Thank you for reaching out. To better understand the problem and assist you effectively, it would be greatly helpful if you could provide an issue video demonstrating the issue.
You may save it through a shareable link like Google Drive and DropBox, then send the link here. We will check this further for you.
1-14 23:49
MJMk
Thank you. Here is the link to the video describing the problem
https://drive.google.com/file/d/1UBKw_SOBavxZ6VU5pde_Q98eN3cQ-jlj/view?usp=drivesdk
Firmware for grip is 01.02.02.00
Lidar 10.00
Focus motor 00.03
1-17 22:13
