The Werewolf
Flight distance : 757651 ft
ryguy80 Posted at 1-14 07:00
The Flip is being sold as a vlog drone. I don’t think DJI had FPV in mind in the design. My question to those that want FPV…why are you looking at this instead of something like the Avata?
The Neo was also sold as a vlog/flying camera and then suddenly it was an FPV drone mainly because it had bumpers. The Flip is a vlog/flying camera and it has bumpers. I genuinely fail to see the real difference here. Also, there are two kinds of FPV flying. The no holds barred unlocked FPV 3 kind that requires a ton of practice and lets you dive down the sides of buildings - and the more sedate pseudo-FPV that you get with the Motion Controller 3 and Mini 4 Pro in "FPV" mode. The Flip is fine for the more sedate kind.
As well, the Avata 2 is around 350g which makes it too heavy for unregistered recreational use in most countries, while the Neo and the Flip are both under the 250g weight limit. A surprising number of drone enthusiasts seem to forget that 250g limit exists. In Canada, for example, a drone under 250g (a microdrone) does not need to be registered, does not need a pilot license and can operate with far fewer restrictions. Giving that up is not a simple decision for a hobbyist.
Finally, the Mini 4 Pro - which is absolutely NOT an FPV drone - DOES support Goggles 3 - so this entire "is it an FPV drone or not" argument isn't even consistent with their higher end goggles.
I have to be honest, while I'm very much a fan of DJI and its products (I own a Mini 2, Mini 4 Pro and a Neo, an RC-2, Goggles N3, Motion Controller 3 and FPV 3 Controller), the whole Neo/Flip/Goggles N3 thing has been a massive disappointment to me.
I have vision issues that require glasses and the Goggles 3 are impossible to use with glasses. A set of prescription lens inserts for it for me would cost more than the goggles, so the N3 was a godsend. But the Neo has SO many bizarre restrictions (like not being able to go over 120m in Canada where that restriction doesn't apply to microdrones - and the Mini 4 Pro doesn't have this restriction, so it's clearly drone by drone) to the wonky behaviour it has in FPV mode making it really unstable for most flights using the Goggles N3 in urban settings even withe the MC3 (and yet it works fine with the RC-2) that I kind of regret buying the Neo in the first place and I almost never have buyer's regret.
I, as did a lot of people, apparently, had expected the Goggles N3 to be the "low end" goggles for hobbyists and that the Flip, which is clearly the "low end" version of the Mini 4 Pro that as I noted, does support Goggles 3, would support Goggles N3.
So right now, I have invested in a Neo Fly More Kit, AND the FPV 3 controller and basically can do very little useful with any of it, and Flip doesn't help at all. I'd buy one in a minute if it supported the Goggles N3, but right now, no combination of DJI hardware results in a practical solution for me.
I still carry the Neo with my Mini 4 Pro and RC-2 controller in a compact shoulder bag, mainly because the Neo can be a little faster to get in the air and to fly into tight spaces and it is light (although because of the restrictions, not as useful as you might think - and it is insanely loud) , but that seems like such a waste of potential. |
