Dji o4 pro not binding to dji n3 goggles
1759 17 1-23 12:49
Ram Kethar
I updated firmware on both the devices, activated the o4 pro unit. but initially before activating the unit I connected only my usb cable to dji o4 pro air unit without powering it on from the fc-battery. suprisingly it got updated and i tried to bind it din't work. so i went again and downgraded the firmware, powered on with fc-battery first and then plugged in my usbc . i got the pop up promt to activate the device. i am sure this is a big bug allowing me to update the firmware without activation?
now after activating the device properly i upgraded the latest firmware -> removed the usb c restarted the fc-battery -> tried to bind again with my n3 goggles it did not work
i tried every possible method downgrading the n3 firmware and resetting again. can someone help me on how to binf o4 pro to n3 goggles?
and the n3 goggles when connected to dji fly app -> connect aircraft button -> there is no o4 pro, but in the goggles it is getting displayed
1-23 12:49
Copterlord
I found the solution myself. After we set the air unit on binding mode(blinking red light). the n3 has a bind button which is the power button. when you hold it for about 3-5 seconds it starts beeping and binds to the air unit. In my g2 everything was different so sorry if you find me dumb...happy flying!!
1-23 13:59
Copterlord Posted at 1-23 13:59
Hi there, we are glad to hear that your problem has been solved. If you have any further questions about the product, please feel free to contact us. Thanks for your great support and have a wonderful day.
1-23 23:40
djiuser_dGYpCLFnjIgH
I’m having a similar problem with a brand new O4 Air Unit (Lite), which will not bind to my Goggles 3.
I also plugged into just USB and updated the firmware, then power the air unit from the battery and activated it, and now it won’t bind.
I’ve switched the goggles to o4 Air Unit, got a blinking red led on the air unit for binding mode, get beeping from the goggles for binding mode but it never binds.
I think my brand new air unit is dead out of the box.
1-24 14:37
DJI Stephen
djiuser_dGYpCLFnjIgH Posted at 1-24 14:37
Hello there,
Thank you for reaching out to us.
Please try the following steps to link your devices:
1. Ensure that both DJI O4 Air Unit and DJI Goggles 3 firmware are updated to the latest version.
2. Power on the DJI Goggles 3.
3. Open the DJI Goggles 3 menu, select "Status," and choose the product you want to link from the top right corner.
4. Power on the DJI O4 Air Unit and ensure the linking status indicator light is red.
5. Press the binding button on the air unit, the red light should start flashing, indicating it is in binding mode.
6. Press and hold the power button on the DJI Goggles 3 until you hear continuous beeping and the battery indicator lights cycle.
7. Once linking is successful, the air unit's binding status indicator light will turn solid green, and the beeping from DJI Goggles 3 will stop, displaying the video transmission.
You can also refer to this video for a detailed guide on the binding process. https://www.dji.com/uk/o4-air-unit/video?backup_page=index
If the binding still fails, please provide us with some footage showing the binding failure so we can investigate further. You can upload the footage to Dropbox or Google Drive and share the link with us.
Thank you for your cooperation.
1-25 02:28
atasoft
Flight distance : 1114898 ft
Turkey
This is definitely a mistake. When you connect the unit to the PC without a battery, you can update without activation. Then, even if you insert the battery, do activation and all the hardware is the latest version, O4 AirUnit and Goggles 3 will not install the Link. But in this way Goggles2 establishes the connection, I have not found any solution for this.
2-10 11:25
fans9fd21dff
Turkey
After assembling the Dji O4 Air Unit, I connected it to the PC via usb without connecting the battery, it did not ask for activation, I did the update. Finally, when I put the battery in, it asked me to activate, I did. Now it does not bind with Goggles 3 in any way. It binds with Goggles 2 but definitely not with 3. I downgraded and then upgraded to the latest version but I didn't get any results.
2-11 02:05
DJI Wanda
fans9fd21dff Posted at 2-11 02:05
Hi, there
Thanks for your information.
We suggest you unbind the O4 Air Unit and Goggles 2 first, then follow the steps as Post #5 to try again.
Please keep us updated after trying, thanks
2-11 23:45
fans9fd21dff
Turkey
DJI Wanda Posted at 2-11 23:45
Hi, there
That's the problem, it didn't connect with Goggles 3 so I connected it to Goggles 2. I have two O4 Air Units. I updated one of them without installing the battery and then activated it after installing the battery and then it did not pair with Googles 3. The other Air unit, after installing the battery and activation, I updated it and it paired with Goggles 3. Now how will I get this problem, this happened because the update was done before activation.
All the hardware I have is in the latest version, I have downgraded and upgraded many times, but the problem still persists, pairing is not possible. How should I proceed? thank you.
2-12 11:14
DJI Tony
fans9fd21dff Posted at 2-12 11:14
Hi there. Please troubleshoot the issue as follows:
Note: To support DJI O4 Air Unit Series, DJI Goggles 3 firmware must be updated to v01.00.0300 or later.
Please verify that the device model selected in DJI Goggles 3 is DJI O4 Air Unit Series.
If the issue persists after the above troubleshooting steps, please send us below information for further analyze.
1. Operation video.
2. Log data from DJI O4 Air Unit Series.
3. Specific test time.
2-12 22:25
fans9fd21dff
Turkey
DJI Tony Posted at 2-12 22:25
I uploaded the log files to the address sent to me. I am currently waiting for the results. Should I send you the link as well?
2-13 01:01
DJI Tony
fans9fd21dff Posted at 2-13 01:01
What address did you upload to? Have you communicated with our online or email customer service staff? If so, could you tell me your ticket ID so that we can help you better. Thank you for your understanding and cooperation.
2-13 01:56
fans9fd21dff
Turkey
DJI Tony Posted at 2-13 01:56
4049584
I uploaded the Goggles 3 and O4 Air Unit log files
2-13 02:59
DJI Tony
fans9fd21dff Posted at 2-13 02:59
4049584
Thank you for your information. We will inform the relevant department that you have uploaded the log. You can also find chat customer service to let them continue to help you solve the problem. Thank you for your understanding and cooperation.
2-13 04:10
fans9fd21dff
Turkey
DJI Tony Posted at 2-13 04:10
Is there a way we can unbind the dji O4 Air Unit?
2-14 11:04
DJI Gamora
fans9fd21dff Posted at 2-14 11:04
Currently, we are checking with our relevant team. Please rest assured that we will get back to you as soon as possible once we receive an update.
Thank you for your understanding and patience.
2-14 12:07
Copterlord
So for me, after activation I connected the unit to the dji assistant 2 pc software and downgraded both my goggles and o4 unit, and then tried binding it worked for me. Maybe it might work for you too... In goggles reset it in the about section it will downgrade automatically.. I think so. Hope it helps
2-15 03:46
djiuser_n3wjzcV3PiYf
Flight distance : 4381148 ft
Copterlord Posted at 2-15 03:46
How did you downgrade and o4 au? I've wanted to do this but in assistant 2 i only have the option to refresh?
3-3 00:40
