gioordie
Good afternoon,
My team currently uses the L1 sensor onboard the DJI Matrice 300, with subsequent processing through DJI Terra.
Having the availability of the coordinates of some ground points on the LiDAR surveyed area, sometimes I involve them into the processing as elevation GCP or check points.
So, I was wondering two main questions:
1. Is it a commonly accepted procedure for enhancing the accuracy along the vertical axis for LiDAR processing?
2. When the Quality Report shows the statistical parameters related to the difference between the altitude of the ground point value and the altitude of the point cloud value, which region has been considered for this type of computation (basically, what is the research radius used?)
Thank you
