djiuser_pu7UBCk5zqxk
Malaysia
djiuser_pu7UBCk5zqxk Posted at 2-25 04:26
DJI can treat the customer like this because there is no competition at the moment. However, once another company comes up with similar products (which will eventually happen one way or another), then DJI will be punched hardly losing lots of its costumers and realise how much frustration it has created.
The worst is that DJI assumes that we, the customers, are stupid and cannot understand the basic. If O4 is compatible with Goggles 2, any other drone using O4 should be compatible with G2, period.
DJI thinks we are stupid and do not understand that O4 system is just a minimal upgrade over O3. Imagin this "Apple says you need to buy a new iPhone every time a new IOS is released. If you have a iPhone originally with IOS 17, you cannot use it with IOS 18 and need to buy a new iPhone." Can you believe this is what DJI is doing us!!!!
FPV Controller 2 connects to Goggles 2, and since O4 is compatible with G2, FPV C2 is also compatible with O4 Air Unit. But when it comes to Neo which uses O4, they dont work. Why? Because DJI wants to sell you G3 and FPV C3, no matter if you just purchased G2 and FPV C2 a few months ago. This is terrible and a dirty trick from DJI. I hope DJI understands this and correct itself. A new compatitor will eventually come up and all your "loyal customers" will dump you exactly the same way you treated them cheaply with these dirty tricks. In FPV world, when Walksnail appeared and created an alternative digital image transmission, many pilots move away from DJI. This will also happen in consumer drone market, unless DJI stops this and realizes that customers can easily see its dirty tricks. With the pressure from US on DJI, there will soon be a couple of consumer drone makers in the market. DJI, please understand we want to loving you and being loyal, but you treats us badly. |
