Original DNG Files in Pano mode
165 3 2-16 15:29
rafafischerfoto
Flight distance : 451749 ft
Brazil
Hi!
About 6-7 years ago, I had a DJI Mavic Pro and one of my favorites uses was to make panoramas with it. With the Mavic Pro, the final panorama was a stitched JPEG file, but it was possible to have the individual images saved in DNG format as I do preffer to process and stitch using my computer.
After all this time without a drone, I got a DJI Flip and after I set it to generate only DNG files, when making panos, the individual panorama tiles are being saved as JPEG. There is a way to get this files as DNG?
Thanks in advance!
2-16 15:29
DJI Gamora
Hello, thank you for reaching out. For the DJI Flip, the stitched panorama photo is saved in JPEG format. However, the individual images used to create the panorama can be saved in either RAW (DNG) or JPEG format, depending on your settings. If you prefer to have the images in RAW (DNG) format, they will appear as shown in the attached example below. If you have any further inquiries, feel free to reach us back. Thank you for your understanding and support.
2-17 10:30
rafafischerfoto
Brazil
I'll try again, but in my test, I set everything for DNG 4.3 48Mp before the pano and when checking the SD card, all files where JPEG...
2-17 19:13
DJI Gamora
rafafischerfoto Posted at 2-17 19:13
Thank you for highlighting the currnet issue. May I check with you if the external microSD card is inserted to capture the RAW footages? This might be the cause if the footage is stored in the internal storage. All images will be stored in JPG.
2-18 03:13
