DJI mini 3 should have active track
297 22 2-21 07:28
djiuser_zZXOaM9xcDBV
Is there a way to give the DJI mini 3 active track because I find it odd that the DJI neo has no obstacle avoidance and yet it has active track.     PS DJI.give the DJI mini 3 active track please.
2-21 07:28
Kikik
Flight distance : 790492 ft
Indonesia
the Neo is able to perform active track / follow because it is meant to be a selfie drone, smaller, slower, has a propeller guard, and won't be too impactful when hit, the camera able to calculate with that size to semi-obstacle avoidance
unlike Neo, Mini 3 has an open propeller, it can't really know how to calculate the size of the drone to perform obstacle avoidance, and likely will hit nor crash something or even someone
that is why the safest to use the active track with a mini-sized drone is only Mini 4 Pro or less Mini 3 Pro, the Flip is also able to perform active track, but it won't avoid obstacles, tho the sensor helps to brake in case near obstacles
2-21 11:10
Kikik Posted at 2-21 11:10
A couple of notes:1 neo uses its camera and downwered sensers to follow your path.
2: The mini 3 pro has only forward,backward and downwered facing sensers which means if it is moving sideways it will crash into obstacles.
2-21 11:40
Kikik
Indonesia
djiuser_zZXOaM9xcDBV Posted at 2-21 11:40
the downward sensor doesnt do anything other than position lock ToF
indeed mini 3 pro doesnt recognize the side of the drone, but it is safer less than mini 4 pro
and it wouldn't follow from side way, unlike mini 4 pro that has a feature to change the direction of follow active track
2-21 11:42
Kikik Posted at 2-21 11:42
Have you seen the DJI neo fly fpv and the DJI avata 2 if you notice they both have that little downward warning.Do you no how many trees My neo has hit.I spent two hours trying to get it.so its camera is not a obstacle senser.its camera only records.
2-21 11:51
Kikik
Indonesia
djiuser_zZXOaM9xcDBV Posted at 2-21 11:51
Have you seen the DJI neo fly fpv and the DJI avata 2 if you notice they both have that little downward warning.Do you no how many trees My neo has hit.I spent two hours trying to get it out.
if you check my post, you probably will figure it out I fly fpv the neo in a forest-like environment
the downward sensor uses ToF to sense the obstacle however, it doesn't avoid it, it's not a visual sensor like camera that mini 3 pro and mini 4 pro have
2-21 11:54
Kikik Posted at 2-21 11:54
You do have a good point but I find it odd that the mini 3 is about as useful as the mini 2.
2-21 11:59
2-21 11:59
Kikik
Indonesia
I didnt say the camera is sensor for obstacle avoidance,
what I meant is the camera acts as a  semi-obstacle avoidance
2-21 12:01
Kikik Posted at 2-21 12:01
It doesn't act like a semi obstacle senser.
2-21 12:02
Kikik
Indonesia
djiuser_zZXOaM9xcDBV Posted at 2-21 11:59
the good thing about mini 3 is its upgrade of mini 2 with vertical shot mode, and doesn't have pro 'mini-ed' features of drones such Air / Mavic
2-21 12:04
Kikik
Indonesia
djiuser_zZXOaM9xcDBV Posted at 2-21 12:02
well then you don't understand how object recognition work in camera
2-21 12:05
Kikik Posted at 2-21 12:04
Vertical shooting is BS.
2-21 12:06
Kikik
Indonesia
I personally never use that
2-21 12:08
Kikik Posted at 2-21 12:08
Nether do I.
2-21 12:09
I have a few questions. What all DJI drones do you have. And do you have any ideas for a good one to get.
2-21 12:12
Kikik
Indonesia
djiuser_zZXOaM9xcDBV Posted at 2-21 12:12
I ever use at least 3 drones now from Dji
Mini SE, Mini 4 Pro, and Neo
I bought from a local official store that is available here in Indonesia
2-21 12:15
Kikik Posted at 2-21 12:15
My only way to get any drones is Amazon.
Do you have any fpv drones?
2-21 12:17
Kikik
Indonesia
djiuser_zZXOaM9xcDBV Posted at 2-21 12:17
Sorry if I misunderstood your question previously
If you want all in one drone I would recommend using Mini 4 Pro
It can be used with a variety of controllers like goggles 3 and RCs
2-21 12:19
Kikik
Indonesia
I use both the Neo and Mini 4 Pro as FPV-like drone using the goggles 3
2-21 12:22
Kikik Posted at 2-21 12:19
No you didn't miss understand just the mini 4 pro is too much for me. I'm trying to get a new drone because my DJI neo got lost.
Unfortunately I forgot Care refresh
2-21 12:24
Kikik
Indonesia
djiuser_zZXOaM9xcDBV Posted at 2-21 12:24
that is very unfortunate, you may able to report to Dji about flyaway aircraft, and if it's not human error, Dji may replace it as long the warranty is still available
I ever heard something about Dji Care Refresh but unfortunately, I can't provide a clear answer about that one, we don't have it here
2-21 12:30
DJI Stephen
Hi there,
Thank you for your valuable suggestions.
We apologize for any inconvenience, but the DJI Mini 3 does not support the Active Track feature. As an entry-level drone with extended flight time, the DJI Mini 3 is more suitable for capturing journeys or beautiful scenery from a high-altitude aerial perspective.
On the other hand, the DJI Neo is designed to offer users a convenient vlog shooting experience with features like palm takeoff and landing, and one-tap shooting, making it ideal for capturing moments in low-altitude, close-range scenarios such as daily walks and gatherings with friends and family.
We appreciate your understanding and support of DJI.
2-22 04:25
