DJI Natalia
Hi there, thank you for reaching out and we do apologize for the trouble caused. Before charging the battery, kindly double precheck the battery as the following:
1.Observe whether the overall appearance of the battery is damaged or bulging, and whether the charging port is abnormal;
This issue indicates that the battery might have been damaged. Do not charge the battery again. It is recommended to provide photos showing the six surfaces when the battery is laid horizontally and the connecting ports to determine subsequent solutions.
2. Press the power button to see if the battery LED1 is always on or flashing or the battery cannot be powered off?
This issue indicates that the battery has been damaged. If the product is under warranty, please send it back for testing. If the product is out of warranty, please purchase a new one.
3. Press the power button once and see if the battery LED 2 and LED 3 are always on or flashing and the battery cannot be turned off?
This issue indicates that the battery is updating the firmware. If the battery level is too low and cannot continue updating, please connect the battery to the charger for about half an hour. Then, mount it into the aircraft to update again. Do not use the battery charging hub for charging a battery during an update.
4. Please check if the battery LED light will light up or not after a long-time charging, press the power button to see if the LED lights up or not. ( If the customer has other batteries, it is charged normally with this charger or not).
If the LED does not light up, which indicates that the battery has been damaged; please advise to send it back for testing within the warranty period, and to purchase a new one if it is out of the warranty period.
Kindly update us the results. Thank you for your understanding. |
