Tele Mode Pocket 3 - Cannot find
537 7 2-26 13:59
Sal107
Hi
I have just updated my Pocket 3 to the latest firmware, but cannot see the on-screen symbol to activate the tele zoom.
Cannot someone help?
Thx
James
2-26 13:59
DJI Gamora
Hi there, thank you for reaching out. You may enable the Med-tele mode as : [ In video mode, tap the < > icon at the bottom of the screen to enable it ]. Once enabled, you can get a 2x magnified mid-focus view (equivalent focal length of 40mm) while maintaining up to 4K ultra-high definition resolution.
If you're unable to enable this function, kindly share us a video recording showing the issue and we will surely provide with an accurate solution after reviewing. Thank you!
2-27 00:06
Sal107
I have checked the firmware and it is the latest, but I do not have this symbol on my screen.
2-27 01:30
Sal107
2-27 02:06
DJI Gamora
Sal107 Posted at 2-27 02:06
Hi there, could you please share us a screenshot showing the interface and the firmware version for us to check further on this and provide you with an accurate solution?
Keep us posted. Thank you!
2-27 02:55
DAFlys
It's only in video mode and only on the normal colour profile, not Dlog etc.    Looks like this to the right of the video resolution    Two arrows above the last O in the Logo.
2-27 05:57
Davey Two Tacos
I had the same issue of not seeing the icon on the screen after the update.
The solution is that you have to turn off Pro Mode on the Pocket 3.
It will show up in video mode after you turn off Pro Mode
3-6 16:50
ProCreative2025
DJI Gamora Posted at 2-27 02:55
I am also limited by this issue, unfortunately.
Tele Mode only works when camera is set to Normal Color profile. Does not work with HLG or D-Log.
I use D-Log exclusively for maximum quality.
Will DJI be updating Tele Mode to work with D-Log (10-bit)?
Attached is an image of my current firmware.
3-13 07:21
