AEB-5 with the same exposure.
314 11 2-28 07:48
Montfrooij
Flight distance : 2958878 ft
Darn.
Just returned from a flight and all my AEB-5 stacks have the exact same exposure.
I'm using the Mini 3 Pro with the RC and both are up to date.
No idea what happened here.
I'm 100% positive that I was on AEB-5 because I have to set this almost every time that I restart the RC.
The other day the app was completely reset to factory standards, so this is the second 'weird' thing that is happening in a short time.
I hope it's the last thing.
2-28 07:48
Blériot53
Flight distance : 7300180 ft
Why did you reset it, Peter?
2-28 12:01
Montfrooij
Blériot53 Posted at 2-28 12:01
I did not.
It was fully reset to factory when I started the app.
But AEB-5 was working then.
Today somehow I got 5 equal images with every AEB-5 shot. Not 5 different exposures.
I will probably fly again tomorrow, but I will make sure to test it out.
2-28 13:05
Blériot53
Montfrooij Posted at 2-28 13:05
I did not.
Let's hope the error will be corrected in a future update
2-28 13:09
Montfrooij
Blériot53 Posted at 2-28 13:09
I did do an update recently, like some weeks ago.
Never had this happen before that (not sure if the update has anything to do with it though)
2-28 13:13
DAFlys
Have you looked at the exif to see the Exposure Bias values?
3-1 01:21
DJI Gamora
We apologize for the inconvenience you have experienced with the AEB-5 on the Mini 3 Pro. We are checking this further with the relevant team and will get back to you as soon as we receive an update.
Thank you for your understanding and patience.
3-1 05:29
Montfrooij
DAFlys Posted at 3-1 01:21
I think I'm to blame. Because the AEB mode is reset every time I start the RC, I have to re select the AEB mode and apparently I selected the multi shot mode.
3-1 09:34
Montfrooij
DJI Gamora Posted at 3-1 05:29
So my question is changed to : why does the photo mode reset to 'one shot mode' every time I shut down and restart the RC a couple of days later?
3-1 09:35
DJI Gamora
Montfrooij Posted at 3-1 09:35
Thank you for your response. Pleease try  to ensure that your aircraft and remote controller is updated to the latest firmware. If it has already been updated, please proceed to refresh the firmware update in DJI Assistant 2.
If the issue persist, please provide the following information for us to inspect further.
1. Flight log
[https://repair.dji.com/help/cont ... ;paperDocType=paper]
2. App log
• Android: Connect the mobile device that has been connected to the aircraft to the PC, the path is as follows: internal storage/Android/data/dji.go.v5/files/LOG (The path of the version before DJI Fly App V1.4.12 is DJI>dji.go.v5>LOG), and then export the data in the "LOG" folder.
• iOS: Connect the mobile device that has been connected to the aircraft to the PC, open iTunes, and then export all data under the "Logs" folder.
3. Screenshot of drone and rc firmware
4. Date and time when the images were taken
We look forward to your update and feedback. Thank you!
3-2 03:12
Montfrooij
DJI Gamora Posted at 3-2 03:12
Oh wow.
That is a lot of work.
Can't you just ask the team if the photo mode should be remembered (AEB) after reboot.
I'm using the RC with the Mini 3 Pro and it keeps resetting the photo mode to single shot almost every time I boot the RC.
3-2 03:36
DJI Gamora
Montfrooij Posted at 3-2 03:36
Oh wow.
We sincerely apologize for the inconvenience. Please attempt the troubleshooting steps provided and update us on the results once you have completed them. Thank you for your understanding.
3-2 04:11
