Mavic3E overexposed images with mechanical shutter
335 14 2-28 16:39
bdwest
Flight distance : 541217 ft
I am on my second Mavic 3E after the first was a replaced after a run in with a power line.  The first Mavic 3E was flawless until it got electrocuted.  The replacement sent by DJI produces overexposed images if the mechancial shutter is enabled.  If it is off the images appear fine.  I assume this is something I need DJI to fix but thought I would see if anyone else has had this issue.
Thanks,
Brian
2-28 16:39
DJI Thor
Flight distance : 13602 ft
Hi Brian, thank you for your inquiry. To assist you effectively, we would appreciate it if you could provide additional details regarding the setting and usage scenario. Additionally, if possible, please share some sample footage for our review.
Furthermore, as you previously indicated that you returned the item for replacement, it would be helpful if you could provide the case number (CAS) associated with that request. This will enable us to address the matter more efficiently. Thank you for your cooperation.
2-28 17:39
bdwest
DJI Thor Posted at 2-28 17:39
The original Mavic 3E was replaced see this case
CAS-18828463-B3Q0M8
If the mechanical shutter is enabled imaged look like this:
If not they are exposed normally.  We are doing orthomosaic mapping with Map Pilot  Pro.  Note the images are over exposed in the DJI Go 4 app as well so it is not Map Pilot Pro
2-28 18:06
DJI Thor
bdwest Posted at 2-28 18:06
CAS-18828463-B3Q0M8
Hi Brian, thank you for your reply. We will further check with our relevant team first and will keep you updated as soon as possible. Thanks.
2-28 20:19
bdwest
Another example. The first image was taken with the mechanical shutter enabled.  The second is with it off. Please provide guidance on what to do.
3-2 17:42
DJI Wanda
Hi, there,
We suggest you set it in Auto mode while the mechancial shutter is enabled.
If the issue still persists, please provide the original footage for further checking.
You may save it through a shareable link like Google Drive and DropBox, then send the link here.
We will forward it to the relevant team and check this further for you.
3-2 20:27
bdwest
DJI Wanda Posted at 3-2 20:27
Hi, there,
There are two images zipped together.  The overexposed image was taken with a mechanical shutter enabled.  The other was not.  Full auto was used on both images.
https://drive.google.com/file/d/ ... Zz/view?usp=sharing
3-4 16:51
DJI Wanda
bdwest Posted at 3-4 16:51
https://drive.google.com/file/d/1Q5emGAl3BF4QIuUAiWpMkkIxKGAaQtZz/view?usp=sharing
Hi, there
Thanks for your information.
We will forward it to the relevant team for further checking,
Kindly appreciate your patience on it.
3-4 19:24
DJI Wanda
Hi, there
After confirming with the relevant team, we suggest you reset the camera parameters.
If the issue still persists, please send the device back to us for repair.
Thanks.
3-5 18:55
DJI Wanda
Hi, there
Since we have not yet received from you.
Kindly remind you to reset the camera parameters, if still failed after trying, please keep us updated.
Look forward to your reply.
3-8 02:52
bdwest
DJI Wanda Posted at 3-8 02:52
Hi, there
Changing the camera parameters has no effect.  I take the camera off auto and use shutter priority it makes no difference.  Is there way of resetting the camera?
3-8 07:34
DJI Wanda
bdwest Posted at 3-8 07:34
Hello bdwest ,
Thank you for your feedback. We suggest enabling the mechanical shutter and using the auto mode for photography to see if the overexposure issue persists. If it does, could you please provide us with relevant materials for further evaluation? You can upload the relevant materials to Google Drive or Dropbox and then share the link with us.
3-8 23:20
bdwest
DJI Wanda Posted at 3-8 23:20
Hello bdwest ,
I have already done that see post:  bdwest Posted at 3-4 16:51
3-8 23:41
DJI Wanda
bdwest Posted at 3-8 23:41
Hello bdwest,
We hope you are doing well and thank you for your feedback. We recommend resetting the camera parameters. If the issue persists, please send the aircraft to the DJI service centre for further diagnostics. You can update us with the new case number and we will help you to take care of it. For more technical support, visit the DJI Enterprise website at https://enterprise.dji.com/?backup_page=index
3-10 02:02
G_Sig
Flight distance : 10464596 ft
Iceland
This is how it is in Dji Go4.
3-10 13:25
