DJI Gamora
Thank you for updating us. May I confirm if you tried your microSD card in your friends's Mini 2? If you did and the issue did not persist, please try these troubleshooting steps to workaround the issue.
1. Please replace the mobile device to have a try. such as an ios or Android mobile device. And please restart the RC, drone, and app before updating again.
2. If the upgrade cannot be done successfully with the App, it is recommended that you update the firmware on the DJI Assistant 2. At present, the DJI Assistant 2 software downloaded from the official website cannot upgrade the DJI Mini 2 directly, but the DJI Assistant 2 can be modified to achieve the upgrade. Please check the below steps:
a. Please download the DJI Assistant 2 (Consumer Drones Series) from the DJI Website;
b. Open the folder where the assistant software is located, and find the "DJI Engine" folder, find "defaultsettings.ini", then open it and change the "0" to "1".
3. Turn on the aircraft and connect the aircraft to the computer within 10 seconds using the data cable. If you connect the computer to the aircraft after 10 seconds, the computer will not be able to recognize the aircraft.
If you need any further assistance, please don't hesitate to contact us. Thank you. |
