Custom Network RTK problem
348 7 3-5 08:22
Pro88Cro
Flight distance : 947871 ft
Croatia
Dear DJI Support,
I am experiencing an issue with RTK connection using a custom network on my M4E. Under clear sky conditions, the RTK status consistently shows "RTK not connected."
I have found a temporary workaround: navigating to the custom network RTK settings, clicking "edit," and then saving the settings without making any changes. This action seems to restore the RTK connection.
Could DJI confirm if this is a known firmware issue? If so, is there a planned fix?
Thank you for your assistance.
3-5 08:22
patiam
Flight distance : 1156358 ft
That's messed up. Thanks for sharing the issue and workaround.
3-6 11:17
Jaybro130
Flight distance : 7545591 ft
Are you getting all constellation connections?  Mine swaps between sats visible and 0 with beidou, gallileo, and Glonass.  This causes converging with no FIX
3-9 16:17
Pro88Cro
Croatia
OK, after more testing I've realized that my first try and "workaround" was pure luck. I either have a "not connected" status or I'm stuck at converging. When I have the "not connected" status, I kill pilot 2 and rerun it, and then the status is stuck at converging.
I only have 0 sats visible when the status is "not connected" (and this is obviously a SW bug).
I don't have a base station to check if this is a network RTK (NTRIP) isolated problem.
I've also tried to lift the drone, but still no success.
Edit: I've now checked at a location where I formerly had success after half an hour of waiting. I had 6/6 success within 30 seconds.
3-16 23:56
patiam
So you're saying that the issue is totally intermittent? As in it doesn't always occur at any given location and when it does the settings edit and/or Pilot restart workarounds don't always work?
3-19 12:55
AR_AirPrecision
Flight distance : 2683589 ft
Belgium
patiam Posted at 3-19 12:55
We had colleagues reporting issues with GPS and Glonass due to the situation in Ukraine, maybe related
3-19 23:56
patiam
Ah yes considering the location... Not exactly next door but who knows how far the effects might range. Good point.
3-20 08:13
Pro88Cro
Croatia
I'm 520km from closest Ukrainian border. Fact is that my Trimble DA2 works just fine with extra quick fix. My colleague reports same problem with his M4E. There is obviously some software bug if asking me...
3-20 09:58
