OldGuy2024
Flight distance : 632428 ft
ralf-djiforum Posted at 3-11 09:21
But what are the limits? If you are outside and have a good number of satellites, that should by within the limits, shouldn't it? And even, if it's going to loose satellites because of a cheap or whatever GPS, full acceleration is a never, never no-go. The NEO is a FAULTY product and flying in its limits for me is only indoors and in places where nobody could be hurt (as far as I can foresee).
Relatively low quality downward facing visual/IR sensors. Known issue since day one. Multiple YTube , the cover the sensor with black tape videos demonstrating even in decent light in N or S mode with an adequate number of satellites the Neo is difficult or uncontrollable. Similar to flying into a deep shadow indoors and even outdoors.
Discovered by accident that if the Neo is facing a very dark object that fills the FOV a warning box pops up preventing taking off in N mode. Had positioned the quad facing the Avata2's black sling bag. Moved, rotated it a few cm laterally. No problem.
Have have experienced a couple indoors "fly away" events due to flying into shadows with both the MC3 and FPV RC3 in N or S modes. Today's indoor session was in a naturally lighted bright area. As usual when flying inside the house. Zero satellites acquired due to steel roof. And as normal no issues flying in N mode as long as I stay in the lighted areas. |
