patiam
Flight distance : 1156358 ft
To create a point cloud and DSM, which are needed for calculating volumes, you'll need to do a proper photogrammetric data collection flight with highly overlapping photos. There is no way to tell you how many images will be needed without knowing the size of the area, desired GSD/altitude, and overlap settings. If you have an RTK-capable drone, you don't need GCPs per se, but it is good to collect a few for use as checkpoints (CPs). CPs are used for accuracy/precision assessment only, unlike GCPs which are used to georeference the project. RTK can eliminate the need for GCPs, but without at least 1-3 CPs, you have no idea what your uncertainty really is. CPs are collected in the same manner as GCPs. Most folks usefabricor rigid high-contrast targets that are set out before the flight and mapped with RTK GNSS. They don't have to be in the same location for each flight, but if you are mapping the same site repeatedly it can be useful to place permanent targets or use existing features, as long as they are easily and unambiguously identifiable in your imagery and can not move. You can use the D-RTK 3 as a rover to mark targets, but if it is anything like the D-RTK 2, there are much better and more appropriately priced units from other vendors. I have a couple of 2's and never use them for marking GCP/CPs. Hopefully DJI improved on the usability on the 3. |
