DJI Gamora
Hi there! Thank you for reaching out. Could you please try the below steps given on connecting transmitter to your mobile phone via Bluetooth.
Transmitter Bluetooth connection to mobile device:
1) With the transmitter powered on, press and hold the transmitter pairing button for 2 seconds, and the transmitter system status indicator will flash blue and green alternately.
2) Enable Bluetooth on your phone, and select DJI Mic Mini-XXXXXX from the discovered Bluetooth devices to connect. The transmitter system status indicator will stay solid blue, indicating a successful connection.
Please Note: This method allows the phone to receive audio through the transmitter. It supports parameter adjustment and firmware upgrades in the DJI Mimo APP. If you need to use the transmitter for audio reception, ensure that the parameter adjustment with TX is disconnected in DJI Mimo. |
