FlightHub Error - "Flight route not performed. No photos availabl...
219 0 3-8 18:19
Mr. HL
Flight distance : ****
South Korea
Hi everyone,
I'm facing a strange issue with DJI FlightHub. Here's what's happening:
I designed a flight route using FlightHub and specifically set the Ground Sampling Distance (GSD) to 5 cm/pixel. I successfully loaded this route onto my remote controller and completed the flight as planned, and all images were uploaded properly, and I also successfully generated cloud mapping result which overlaid on my map.
However, when I go to "Model Library" and select "Start Mapping" to initiate mapping from the captured images, the "Mapping Photos" section shows the designed route but gives me an error stating "Flight route not performed. No photos available." Additionally, it incorrectly displays the GSD as 0.1 cm/pixel, despite having clearly set it to 5 cm/pixel.
I also tested this by creating another project, setting the GSD again to 5 cm/pixel (without performing the flight), and found that the GSD still shows up as 0.1 cm/pixel.
Has anyone experienced similar issues? Could this be a bug, or am I missing something?
Any insights or advice would be greatly appreciated.
Thanks!
3-8 18:19
