Ian Craig
It doesn’t work the same way on the Action cameras unfortunately. For instance on my Sony and Canon cameras, I can point at a grey card and the camera works out the colour temperature from that automatically. With the Action 5, you can only dial in a temperature while looking at the screen.
So, point the Action 5 at a grey card in auto while looking at the WB reading in the Pro menu. That gives you the colour temperature so then you can dial that in on manual and tweak it. In effect, the colour temperature is only moving from orange to blue. There's no subtlety there which exists in better cameras.
Unfortunately, I find that the same number in auto doesn’t always look the same as in manual on the Actions cams.
As an example, I have a slightly primrose yellow wall. In auto, the camera tries to reproduce it as white. Take a grey card reading and then switch the manual to the same setting and then the wall goes a slightly salmon colour. I can’t get the correct colour at any setting because it needs a ‘tint’ applied which doesn’t exist on the Actions.
The auto does a pretty good job. If it looks off, then the manual is there to tweak, but they’re not the most accurate in comparison to my Sony or Canons which give me a yellow tinted wall! Not surprising I guess given the price difference!! |
