djiuser_ql5XeH6UOXk3
So I have a diesel heater, https://www.amazon.com/HCALORY-Portable-Control-Monitor-Parking/dp/B0DNT95NVC
It draws about 140w when starting. It takes 12v or 24v DC as input.
The DJI power 1000 SDC port can output 280W(at 28V). It should be enough to power this diesel heater. I just need to find the right cable that can tell the SDC to output 24V
I have tried the cart port cable, https://www.amazon.com/dp/B0CZ3P995F, seems it tells SDC port to output 12V, 12v is not enough, because the maximum AMP is 10amp? What actually happened, is I saw the voltage dropped from 8V to 5V, it could not start the diesel heater.
Could you tell which SDC cable can tell the SDC port to output 24V? Or can it be done at software level(like an option in app). Thank you
