How to tell SDC port to output 24V?
98 0 3-12 07:53
Greenshell
I have a diesel heater, https://www.amazon.com/HCALORY-Portable-Control-Monitor-Parking/dp/B0DNT95NVC
It needs about 140w when starting, it takes 12V or 24V DC as input.
At 12V, it needs about 12amp to start, 12amp is too much for the SDC port, since the amp limit of 10amp.
So 24V is the only way to go.
How can I tell the SDC port to output 24V? Or which SDC cable can tell SDC port to output 24V?
I already tried the SDC to car charger cable, it did not work. https://www.amazon.com/dp/B0CZ3P995F. Looks like the cable tells SDC port to output 12V.  And I saw the start voltage at 8V then dropped to 5V on my diesel heater, because it could not output the desired watts(140w)
So my question falls to, which SDC cable can tell the DJI power 1000 SDC port, to output 24V DC current?  Thank you
3-12 07:53
