Prometheus Xex
Flight distance : 178068 ft
Rnfaust Posted at 2015-10-28 18:37
"I thought I should keep the coverage as thin as possible. There is considerable weight difference in weight between a full and an empty paint can."
Technically you don't have to worry about the few grams of paint sprayed on. Your Phantom won't notice the difference... even if it's 4 coats. Rememer, much of that cans weight is in the solvent the solids of the colour are suspended in. Once you spray it, and the solvents flash off during drying, there's not much weight on each coat.
