gregg1r
You can't draw any conclusion on the video stability as the 3DR copter used a non stabilized gimbal, the Phantom used a stabilized gimbal and the $100k copter used who knows what.
The $100 copter image if you look at it on a large screen you can see there is a issue getting the FPV signal and what is being displayed is only using a small part of the screen. Also, I don't see an antenna attached to the hardened laptop used.
The IPad that the Phantom used was very brilliant, almost life like.
To draw any conclusion, you need to inspect the finished video, which we haven't seen. The only full sized video is from the 3DR Solo, but like I said, the gimbal isn't stabilized. |
