4K video freezes and reboots
12
7707 58 2015-10-26
DJI-Amy
tupoleff Posted at 2015-12-14 17:39
Crash at every resolutions
Hi, please upload the original files shooting different resolution into dropbox or MEGA and provide the download link here.
2015-12-14
DJI-Amy
tupoleff Posted at 2015-12-14 17:38
I take these video this morning, record button down and a few second later the recording stops, b ...
Osmo only have this blue screen problem for the resolution 4K 4096*2160 24P. If you have this problem for the other resolutions, please send the original files in the SD card and contact the dealer or DJI technical support for repair or replacement.
2015-12-14
tupoleff
DJI-Amy Posted at 2015-12-14 11:23
Osmo only have this blue screen problem for the resolution 4K 4096*2160 24P. If you have this prob ...
Ok thanks for The answer, yes my Osmo crashes in every résolutions...
2015-12-14
DJI-Amy
tupoleff Posted at 2015-12-14 19:00
Then your Osmo might have a hardware issue, please contact your dealer or DJI technical support for repair or replacement.
2015-12-14
tupoleff
DJI-Amy Posted at 2015-12-15 02:38
Then your Osmo might have a hardware issue, please contact your dealer or DJI technical support fo ...
I did contact Dji Technical  support, The return Of The Osmo was accepted and waiting  y for a new one !!!
The Dji support answered me very quickly...
2015-12-15
DJI-Amy
tupoleff Posted at 2015-12-15 20:19
I did contact Dji Technical  support, The return Of The Osmo was accepted and waiting  y for a new ...
Great to hear that. I hope you get your new one soon.
2015-12-15
tupoleff
DJI-Amy Posted at 2015-12-16 02:43
Yep back on The forum soon with good News !
2015-12-16
jossjam
Mexico
Creo que DJI debe corregir el problema con el joystick de Osmo, ya que la cámara se mueve solo horizontal ó solo vertical, pero nunca en ambos al mismo tiempo, y solo es posible desde go app. Otro problema que debe corregir es grabar con resolución UHD: 4K (4096 x 2160) 24/25p, ya que al seleccionar que osmo grabe a UHD: 4K (4096 x 2160) 24/25p el Osmo se traba, o se reinicia con pantalla azul.... algún otro problema que crean necesario corregir?
2015-12-16
jossjam
Mexico
DJI-Amy Posted at 2015-12-9 23:44
You mean you have all the N/A for the camera OSD? Please try to restart and reset the camera setti ...
En ocasiones formateando la memoria directamente desde osmo, puede que corrija ese detalle.
2015-12-16
DJI-Amy
jossjam@hotmail Posted at 2015-12-16 22:26
Creo que DJI debe corregir el problema con el joystick de Osmo, ya que la cámara se mueve solo hori ...
Hi, I am sorry, could you please translated it into English? Thanks.
2015-12-16
tupoleff
Got a new Osmo yesterday Now everything works fine, great job from The Dji osmo support team...
2015-12-30
DJI-Amy
tupoleff Posted at 2015-12-30 21:57
Thanks for your compliment.
2015-12-30
shina70
Russia
I have the same problem, where to find me?
2016-2-13
DJI-Adela
shina70 Posted at 2016-2-13 21:33
Hi, the former problem of blue screen in 4K 4096*2160 24fps setting has been fixed in the latest FW version, if you've tried to upgrade the FW but still could not solve it, I'm afraid it may not be the same issue, so could you please describe the problem you're facing to us again?
2016-2-14
realityryan
*BUMP* ..
Had this problem this morning when flying.
I was running on my ipad which, I just flashed and is running ios 9.2.1 and the latest version of DJI go. Upon trying to record ANY video or take a photo the app will momentarily crash (or flicker) the DJI logo will appear and then the video feed will return. I rebooted my ipad, uninstalled and reinstalled the app, reset the video settings, formatted the SD.
No beuno.
When I got home, I tested the video functionality with my iphone which is running 9.2 and there was no problem recording video at any resolution (or taking pictures).. this appears to be a problem with my ipad only and perhaps is related to the latest version of the software. When I get home I'm going to try rebinding the controller to the ipad and see if that makes a difference.
But just to reiterate this is clearly a software issue as it completly works with my iphone (ios 9.2) and not with my ipad (ios 9.2.1) both are running the same version of DJI Go. Also just to restate...I have already rebooted the ipad(restored it completely to factory settings) and installed the DJI GO app, I've re-formatted the SD.
2016-3-11
gquek84
Singapore
Bought my dji osmo 2016 May and still the 4k freeze while play...I mean it freeze 0000.1sec and keep going on...any dji professional guys wanna en-lighten?
2016-5-26
DJI-Adela
realityryan Posted at 2016-3-11 22:10
*BUMP* ..
Hello.
If this problem persists, we would suggest you to re-install your ipad's iOS or upgrade your iOS.
Any further feedback would be appreciated.
Thanks.
2016-5-26
DJI-Adela
gquek84 Posted at 2016-5-27 09:44
Bought my dji osmo 2016 May and still the 4k freeze while play...I mean it freeze 0000.1sec and keep ...
Hi gquek84,
Let's discuss your same case in your own post: http://forum.dji.com/thread-53729-1-1.html
Thanks for your cooperation.
2016-5-26
Yiliayoung
How about trying a high-quality Joyoshare Screen Recorder? The problem may be caused by the high space occupation of 4K video. With this mentioned tool, it's available to change resolution, codec, frame rate, and more in an advanced mode. Also, it can record in high quality.
2020-3-2
12
