shaybowskill
I'm having the exact same issue at the moment. Only had the thing for a day, only recorded about 20 minutes of footage. The top arm rolls violently on start up. I've noticed that if it is pointing below horizontal when I power it on, that section of the gimbal will lock itself. However, if it is positioned above horizontal (even slightly) on start up, it will roll vertically fast enough for the UV filter to scratch against the arm of the gimbal, damaging both parts.
After updating the firmware, rather than swinging violently, it glitches and rapidly moves up and down by a few degrees before going limp and beeping.
Going to the store tomorrow to see if I can get a replacement like you did Grant. |
